Warning message
CSS Script for checking RADIUS Service
Jun 14th, 2006
We are using CSS 11501 boxes for load-sharing RADIUS (NAC) requests between different ACS Servers.
How can I configure a keepalive method for checking the RADIUS service on the ACS Servers ?
If this needs to be a script then Can anyone provide some hints\tips ?
Naman
Gilles Dufour Thu, 06/15/2006 - 05:39
  • Cisco Employee,
This needs to be a script.
The best way would be to sniff a request/response from a known user [or fake user], then extract the udp header + payload in hex format, then create a CSS script to send the hex formatted query and to verify that the hex formatted response matches the server response.
I believe the ap-kal-dns script uses a similar approach so you can look at it to get an idea of what you have to do.
Gilles.
