Warning message
CRA - Voicemail Routing
Jun 15th, 2006
Using CRA 3.5, trying to figure a way by scripting, when a client is prompted to presses a menu number it routes to a number listed in a line group - if it receives a voicemail and not a LIVE person have that call rotate to the next line in the hunt group. Not sure if it's even possible.
Thanks in advance.
Jim
Overall Rating: 4 (1 ratings)
fmeetz Wed, 06/21/2006 - 07:29
  • Bronze, 100 points or more
Nope. It's not possible.
adignan Sat, 06/24/2006 - 16:59
  • Blue, 1500 points or more
Actually, if you wanted to be creative you could do this.
For the Voicemail Profile of each of these individuals, put in a Route Point DN that triggers an IVR script.
In the IVR script, check if the "original called number" is the DN of the hunt pilot. If yes (true), this means the call came in from the IVR script and you could "redirect" the call back to the hunt pilot.
If false, this means the call was made directly to this individual and "redirect" the call to the "original called number" which will be the persons extension. You will need to configure crs with the ability to route calls "directly into voicemail" in order for the second part to work so you will need to "prefix" a number to the "original called number" to get it to work.
Follow another one of my posts below in order to redirect calls directly into vm from a script:
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40.1dd6422c/0#selected_message
It sounds like a lot of work but actually quite easy once you get to scripting it.
please rate helpful posts.
adignan - berbee
Jim Augherton Mon, 06/26/2006 - 02:46
Thanks, new to scripting but will give it a try - at least it's a place to start.
