Monitor bandwidth of entire VLAN
Jun 16th, 2006
Is there a mechanism by which I can monitor the bandwidth across an entire VLAN? I have about 100 servers in one VLAN (currently located in the same building as my user base) and I would like to know how much bandwidth I need if I were to relocate the servers to a different data center. Any help is appreciated.
Marvin Rhoads Fri, 06/16/2006 - 06:39
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 Firewalling, Network Management, VPN
Are your servers in a different VLAN than your user base?
If so, there must be a layer 3 interface that routes traffic from the server VLAN to the user VLAN(s). It's that interface or subinterface whose traffic load your would need to measure. A simple performance monitoring tool such as MRTG can handle that task easily.
If not, you will be moving them eventually so why not just administratively separte them into a different VLAN before physically moving them? If you assigned IP addresses in a well-thought out manner, you might not even have to make any changes on any servers or clients, just a new L2 domain (VLAN) with associated L3 (routing) interfaces on your router or routing switch which you can then monitor as above.
If for some reason they are all mixed in with user VLANs, you have a much more complex task at hand and would need to monitor many individual interfaces (could still use MRTG), but you would have to somehow factor out any server-server communications - not easily done if they are within a given VLAN unless one resorts to packet analysis type tools - probes, sniffers, etc. - and that tool set doesn't scale well to considering 100 servers at once.
