Warning message
I use Cisco IOS DHCP but I can not get the IP from manual binding.
Jun 18th, 2006
Could anybody help me? First of all, I have to tell that I just start to learn for Cisco switch, Cisco router.
I'm trying to automatically assign IP for switches which connect to router for some testing. The IP from automatic binding is assigned correctly but the IP from manual binding is not assigned to the specific switch.
Assume that I did the manual binding for switch A (IP : 192.168.0.60 MAC address 0013.5f0c.fec2) but when I check the assigned IP of switch A, the IP is not 192.168.0.60 but it is the IP from automatic binding pool (192.168.0.61).
How can I assign the IP from manual binding pool to the switch A? Please take a look at the configuration of the router as following.
ip subnet-zero
ip dhcp excluded-address 192.168.0.0 192.168.0.50
ip dhcp pool ts1pool
network 192.168.0.0 255.255.255.0
default-router 192.168.0.47
domain-name ts1domain.com
dns-server 192.168.0.1
lease 7
ip dhcp pool macc3
host 192.168.0.60 255.255.255.0
hardware-address 0013.5f0c.fec2
client-name macchiato_3
interface Ethernet0
ip address 192.168.0.47 255.255.255.0
interface Serial0
no ip address
shutdown
And this is the results from "sh ip dhcp binding" command
termserver1#sh ip dhcp binding
IP address Hardware address Lease expiration Type
192.168.0.60 0013.5f0c.fec2 Infinite Manual
192.168.0.61 0063.6973.636f.2d30. Jul 25 1993 02:35 AM Automatic
3031.332e.3566.3063.
2e66.6563.322d.566c.
3330
When I check at switch A, the IP 192.168.0.61 is assigned.
One more thing, please notice that actually MAC address of switch A is 0013.5f0c.fec2 but why it show
" 0063.6973.636f.2d30.3031.332e.3566.3063.2e66.6563.322d.566c.3330 " in "sh ip dhcp binding" command.
Help me please!!!!!
Thanks a lot.
-FILL-
Overall Rating: 3.4 (5 ratings)
Roberto Salazar Sun, 06/18/2006 - 11:10
  • Gold, 750 points or more
show version should actually tell you the switch's mac address, if this is a switch running IOS. and have you tried not putting the manual binding in a separate pool?
ssukpool Sun, 06/18/2006 - 23:13
Well, after I used "show version" command on switch A, I can get MAC address as following :
90K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:13:5F:0C:FE:80
Motherboard assembly number : 73-9833-02
Motherboard serial number : FHH0913012Y
Motherboard revision number : 03
System serial number : FHH0913012Y
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
* 1 26 WS-CE500-24LC 12.2(0.0.232)SEG CE500-LANBASE-M
This MAC address is bound with specific IP (192.168.0.60)
But when I used "show ip int brief" command on the switch A, the IP from automatic binding was assigned (192.168.0.61) instead of manual binding as below :
Macchiato3#sh ip int brief
Vlan1 172.20.249.11 YES manual up down
Vlan30 192.168.0.61 YES DHCP up up
FastEthernet1 unassigned YES unset down down
FastEthernet2 unassigned YES unset up up
BTW, I have tried not putting the manual binding, so the automatic binding is assigned properly (I mean the switch A get any automatic IP from DHCP server properly).
However, I would like to test DHCP feature by using the specific IP to switch A , using automatic IP for others.
Please advise me.
-FILL-
olorunloba Mon, 06/19/2006 - 00:31
  • Silver, 250 points or more
Different physical interfaces on the switch have their unique mac addresses. You need to find out which interface the switch is using to talk to the router. One way to do this is to look for which interface is on the vlan 30.
Another thing you can do, is to use the mac address in the automatic binding for the manual binding.
For a list of all the mac addresses on the switch, issue the command sh mac address static.
Roberto Salazar Mon, 06/19/2006 - 13:57
show interface vlan 30 would give you the mac-address for that SVI. what is the mac-address for interface vlan 30?
ssukpool Tue, 06/20/2006 - 10:15
After I have been trying to do, I get the information like this.
1). The interface Fa2 is on vlan 30.
2). When I use "show int vl 30", I get this info :
Macchiato3#sh int vl 30
Vlan30 is up, line protocol is up
Hardware is EtherSVI, address is 0013.5f0c.fec2 (bia 0013.5f0c.fec2)
Internet address is 192.168.0.62/24
MTU 1998 bytes, BW 1000000 Kbit, DLY 10 usec,
3). Right now all binding IP on router as following :
192.168.0.62 0063.6973.636f.2d30. Aug 01 1993 10:13 AM Automatic
3330
Same thing, the automatic binding IP is assigned to switch A (Macchiato3) instead of the manual binding IP.
So that I try to use the MAC address from automatic binding for manual binding, I get this error message :
termserver1(dhcp-config)#hardware-address 0063.6973.636f.2d30.3031.332e.3566.3063.2e66.6563.322d.566c.3330
% DHCP could not parse the hardware address. Check character 39 (.).
In other words, I use this MAC address, it's ok.
termserver1(dhcp-config)#hardware-address 0013.5f0c.fec2
4). When I use "sh mac address-table static", the information as following :
Macchiato3#sh mac address-table static
Mac Address Table
Vlan Mac Address Type Ports
All 0100.0ccc.cccc STATIC CPU
All 0100.0ccc.cccd STATIC CPU
All 0180.c200.0000 STATIC CPU
All 0180.c200.0001 STATIC CPU
All 0180.c200.0002 STATIC CPU
All 0180.c200.0003 STATIC CPU
All 0180.c200.0004 STATIC CPU
All 0180.c200.0005 STATIC CPU
All 0180.c200.0006 STATIC CPU
All 0180.c200.0007 STATIC CPU
All 0180.c200.0008 STATIC CPU
All 0180.c200.0009 STATIC CPU
All 0180.c200.000a STATIC CPU
All 0180.c200.000b STATIC CPU
All 0180.c200.000c STATIC CPU
All 0180.c200.000d STATIC CPU
All 0180.c200.000e STATIC CPU
All 0180.c200.000f STATIC CPU
All 0180.c200.0010 STATIC CPU
All ffff.ffff.ffff STATIC CPU
Total Mac Addresses for this criterion: 20
5). When I use "sh mac address-table dynamic", the information as following :
Macchiato3#sh mac address-table dynamic
Mac Address Table
1 0002.b395.a3f0 DYNAMIC Fa1
1 0011.1100.256f DYNAMIC Fa1
1 0011.936b.6f0c DYNAMIC Fa1
30 000d.2818.ab97 DYNAMIC Fa2
30 0011.20df.6ec0 DYNAMIC Fa2
30 0011.955b.90d5 DYNAMIC Fa2
30 0013.462c.fb2e DYNAMIC Fa2
30 0013.462d.089b DYNAMIC Fa2
Total Mac Addresses for this criterion: 8
** If my info can not answer your questions, please teach me what you do about automatic binding and manual binding on the same
router.
Thanks a lot
-FILL-
Roberto Salazar Sat, 06/24/2006 - 16:00
Took me some time but I found why the switch is giving this client-id "0063.6973.636f.2d30.3031.332e.3566.3063.2e66.6563.322d.566c.3330 " and thus it does not match your hardware address and as a result it does not assing the static mac address.
From what I found, the dhcp server will look at the client indentifier in the dhcp
discover packet and use that, not the mac address. How do you know what the client
identifier is? You have to either use a sniffer or turn on debugs on the dhcp server.
Here are the debugs on the dhcp server
Router4#debug ip dhcp server packet
Router4#debug ip dhcp server events
Router4#
*Dec 29 20:15:43.527: %OSPF-5-ADJCHG: Process 1, Nbr 3.3.3.3 on Ethernet0/0 from
LOADING to FULL, Loading Done
*Dec 29 20:16:27.479: DHCPD: DHCPDISCOVER received from client 0063.6973.636f.2d
61.6162.622e.6363.3030.2e30.3630.302d.4574.302f.30 through relay 10.1.1.1.
*Dec 29 20:16:27.479: DHCPD: Sending DHCPOFFER to client 0063.6973.636f.2d61.616
2.622e.6363.3030.2e30.3630.302d.4574.302f.30 (10.1.1.10).
*Dec 29 20:16:27.479: DHCPD: unicasting BOOTREPLY for client aabb.cc00.0600 to r
elay 10.1.1.1.
*Dec 29 20:16:27.619: DHCPD: DHCPREQUEST received from client 0063.6973.636f.2d6
1.6162.622e.6363.3030.2e30.3630.302d.4574.302f.30.
*Dec 29 20:16:27.619: DHCPD: Sending DHCPACK to client 0063.6973.636f.2d61.6162.
*Dec 29 20:16:27.619: DHCPD: unicasting BOOTREPLY for client aabb.cc00.0600 to r
elay 10.1.1.1.
*Dec 29 20:16:57.419: DHCPD: checking for expired leases.
*Dec 29 20:18:57.431: DHCPD: checking for expired leases.
Here is the config on the dhcp server. Notice the client id
ip dhcp pool tes
network 10.1.1.0 255.255.255.0
default-router 10.1.1.1
ip dhcp pool host_test
host 10.1.1.10 255.255.255.0
client-identifier 0063.6973.636f.2d61.6162.622e.6363.3030.2e30.3630.302d.4574
.302f.30
The client identifier uses ASCII hex characters.
I you use an ascii hex to ascii symbol conversion chart you see the following.
There is a complete chart at
http://www.ascii.cl/index.htm
Cool, eh!
Tim Ryan
00 nul
63 c
69 i
73 s
63 c
6f o
2d -
-----------begin mac address---
30 0
30 0
30 0
35 5
2e .
33 3
31 1
33 3
65 e
2e .
39 9
63 c
30 0
30 0
------begin interface (swtich vlan1 = vl1 ; router = -et0/0) 2d -
56 V
6c l
31 1
Switch's real mac address = 0005.313e.9c00
client-identifier becomes
0063.6973.636f.2d30.3030.352e.3331.3365.2e39.6330.302d.566c.31
nul c i s c o - 0 0 0 5 . 3 1 3 e . 9 c 0 0 - v l 1
Got it?
Please rate all posts.
saxenapankaj7 Sat, 07/08/2006 - 10:42
Hi Could you please suggest the meaning of following error.
Internet 1.1.1.2 0 Incomplete ARPA
%OSPF-5-ADJCHG: Process 100, Nbr 1.2.2.3n FastEthernet0/0 from 2WAY to DOWN, Neighbor Down: Dead timer expired
Brgds
Pankaj
Roberto Salazar Sat, 07/08/2006 - 13:10
>> Measn devices with ip address 1.1.1.2 is not responding to the router's ARP request, maybe the device had been taken out of the network or it's down.
>> Means OSPF neighbor 1.2.2.3 on FE0/0 is not sending OSPF hello or this router is not receiving the OSPF hello.
