Warning message
Changing IPCC X 4.0(3) prompts from G.729a to G.711?
Jun 19th, 2006
  • Bronze, 100 points or more
When installing IPCC Express 4.0(3) it asked if I wanted to use G.729a or G.711. I selected G.729a and now want to change my mind. I've re-configured my scripts to use prompts with G.711, now how do I change IPCC to have prompts use G.711?
adignan Mon, 06/19/2006 - 15:33
  • Blue, 1500 points or more
Hey jason,
you have to re-run the setup (so insert CD1 and run through the install again). You won't lose any data by re-running setup but I would still recommend taking a good BARS backup to be safe.
Look for this paragraph in "Changing Installation Information After Installing" section at this link:
http://www.cisco.com/univercd/cc/td/doc/product/voice/sw_ap_to/apps_4_0/english/administ/crs404ig.pdf
"Perform the Cisco CRS installation
procedure, entering new information as
needed. See the ?Installing the Cisco
CRS Software? section on page 5-3."
please rate helpful posts.
adignan - berbee
