Serial0/0/0:23 is up, line protocol is up (spoofing) - Help
Jun 19th, 2006
I am trying to get my isdn working. I need assistance in troubleshooting this error message.
NNN0R011#sh int serial 0/0/0:23
Hardware is DSX1
MTU 1500 bytes, BW 64 Kbit, DLY 20000 usec,
Encapsulation HDLC, loopback not set
Last input 00:00:03, output never, output hang never
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/1/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 48 kilobits/sec
1722 packets input, 6556 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
1 input errors, 1 CRC, 0 frame, 0 overrun, 0 ignored, 1 abort
Please help
Overall Rating: 5 (1 ratings)
pciaccio Tue, 06/20/2006 - 02:28
  • Silver, 250 points or more
There is no error in your display. If you are concerned about the up/up spoofing, then that is normal behavior. The D-channel is kept up spoofing to keep the ISDN switch and the router talking..Do you still have an error or an issue??
