Spanning a port on a 3548
Jun 20th, 2006
Can you set a port on a 3548 to Spanning mode?
So i can capture all the data that is going into the switch from one port.
I cant seem to find a command that allows me to make the port a span port.
Many thanks.
Mike.
Overall Rating: 5 (1 ratings)
leonvd79 Tue, 06/20/2006 - 03:26
  • Silver, 250 points or more
Hello Mike,
Yes you can. See the example below.
Enable SPAN on interface Fa0/1 to monitor interface FA0/2.
conf t
int fa0/1
port monitor interface Fa0/2
end
Disable SPAN on interface Fa0/1
conf t
int fa0/1
no port monitor interface Fa0/2
end
Refer to the documentation for more information:
http://www.cisco.com/univercd/cc/td/doc/product/lan/c2900xl/29_35wc/sc/swgports.htm#1035723
Leon
* Please rate posts.
