If you are talking about a static default route i.e. 0.0.0.0/0,you can use a floating static route.
For instance
Route from 3750 to 2821
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0/1 distance 10
Route from 3750 to 3750
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0/2
In case you are connected to the office 3750, that route is preffered. When the interface goes down, the route disapears from the routing table.
--Leon
* Please rate posts.
