Router configuration help for NAT and DHCP
Jun 20th, 2006
Want the setup to be in such away that the router will be doing:
NAT, inside might be 10.1.1.1/24 and outside will be IP issued by ISP - 202.62.x.x
Router to also act as a DHCP server issuing out IP to a workshop participants.
Do you have a template/docs anywhere that might be of any help
Please let me know
Overall Rating: 4.5 (4 ratings)
Roberto Salazar Tue, 06/20/2006 - 20:36
  • Gold, 750 points or more
The following sample config should be self explanatory, however, if you have any specific questions, fire away:
ip dhcp excluded-address 10.1.1.1 10.1.1.99
ip dhcp pool private
network 10.1.1.0 255.255.255.0
domain-name anydomain.net
default-router 10.1.1.1
dns-server x.x.x.x y.y.y.y
lease 3
interface Ethernet0
ip address 10.1.1.1 255.255.255.0
ip nat inside
interface Ethernet1
ip address dhcp hostname blah
ip nat outside
ip nat inside source list 1 interface Ethernet1 overload
access-list 1 permit 10.1.1.0 0.0.0.255
Please rate helpful posts.
leonvd79 Tue, 06/20/2006 - 20:57
  • Silver, 250 points or more
Hello utawakevou,
Here you have a sample configuration. I do not know what the pool size of your public is, so I used a class "C" in this example.
ip dhcp pool workshop-dhcp
network 10.10.1.0 255.255.255.0
domain-name myworkshop.com
dns-server 10.10.1.x
ip dhcp exclude-address 10.10.1.1
ip dhcp exclude-address 10.10.1.x
ip nat pool workshop-nat 202.62.123.2 202.62.123.254 prefix-length 24
ip nat inside source list 1 pool workshop-nat
ip access-list standard 1
permit 10.10.1.0 0.0.0.255
interface FastEthernet 0/0
ip addr 10.1.1.1 255.255.255.0
ip nat inside
interface Serial 0/0
ip nat outside
202.62.123.1 255.255.255.0
Here are some helpful links to IOS configuration guides:
DHCP
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cg/hiad_c/ch10/index.htm
NAT
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cg/hiad_c/ch20/index.htm
--Leon
* Please rate posts.
leonvd79 Tue, 06/20/2006 - 21:45
To avoid confusion, the configuration provided by bosalaza is for nat overloading, that is if you have a single public IP address.
If you want all hosts to have unique public IP address from a outside global perspective, the second solution will suit your needs.
Best of luck!
Leon
utawakevou Wed, 06/21/2006 - 13:10
I beleive this is what I need and thak you for that. We might be having one public IP issued by the ISP and about 30-40 private IP's for the workshop participants. As for the DNS, that will be a public one or a private one ?
Roberto Salazar Wed, 06/21/2006 - 14:53
Usually, the ISP would provide you the ip addresses of their DNS but if you have DNS server, you can use that as well.
Please rate all posts.
utawakevou Wed, 06/21/2006 - 15:29
Thanks. That was what I was thinking of. I know the ISP DNS so I will use that one.
skhawari83 Wed, 03/01/2017 - 16:19
Did you manage to get this resolved. I want to setup something similar.
utawakevou Wed, 03/01/2017 - 16:42
Yes, it worked out and that was eleven years ago :)
skhawari83 Wed, 03/01/2017 - 17:05
Hehe. Do you mind sharing the running config please if available.
utawakevou Wed, 03/01/2017 - 18:40
Sorry, I don't have the running configuration as I told you that was 11 years ago. However I just follow the examples posted here. See if you can go through the examples on this thread and you should be good. Be good to draw things out first, allocate the IP address and subnets for your interface then you go ahead and configure it
Hope this helps
