DFM (20.4): High Utilization & High Broadcast rate
Jun 21st, 2006
Hello all,
I'm continuously receiving following alerts from DFM
ALERT ID = 00000X5
TIME = Wed 21-Jun-2006 04:37:01 EDT
STATUS = Active
SEVERITY = Critical
MANAGED OBJECT = 172.16.225.101
MANAGED OBJECT TYPE = Switches and Hubs
EVENT DESCRIPTION = PORT-172.16.225.101/15.1 [15/1]:HighUtilization; PORT-172.16.225.101/15.1 [15/1]:HighBroadcastRate; 172.16.225.101: STP Topology Change:MinorAlarm;
Wherein in the event details shows
EventID: 00001B5
Property Value
Component PORT-172.16.225.101/15.1 [15/1]
OutputPacketRate 2889.8174 PPS
Type PROPVIRTUAL
CurrentUtilization 6.1234008E10 %
InputPacketRate 2924.9668 PPS
TrafficRate 7.6542511E16 BYPS
UtilizationThreshold 50
DuplexMode FULLDUPLEX
MaxSpeed 1000000000
The threshold limit is set as 50 for Utilization and 30 for Broadcast.
This message is very frustrating since it is been generated for each Cat 6500 and once every one to two hours.
Please suggest any configuration (bug) changes to stop these kind messages.
tmpnpo
n.bowbridge Wed, 06/21/2006 - 16:11
  • Bronze, 100 points or more
DFM requires quite a bit of tuning especially the notification alerts. I found setting my thresholds for 85% util, 45% broadcast only alerts me when there is a problem in the network. Adjust the thresholds on the configuration page and see what works.
Once your threshold levels are setup correctly the alerts will clear. Preventing the 100's of useless emails every day!
