Warning message
vpn 3015 ike sha parameter
Jun 22nd, 2006
Can I pin up a ipsec lan-to-lan tunnel using the "hybrid_aes128_sha_rsa_dh2" ike parameter having the following hardware and software setup without any performance degradation?
VPN Concentrator Type: 3015
Serial Number:CAM01380303
Bootcode Rev: Cisco Systems, Inc./VPN 3000 Concentrator Series Version 2.5.Rel Jun 21 2000 18:57:52
Software Rev: Cisco Systems, Inc./VPN 3000 Concentrator Version 4.1.6.Rel Aug 23 2004 19:21:58
Up For: 235d 19:36:04
Up Since: 10/29/2005 20:27:52
RAM Size: 128 MB (Memory Status: Green)
