Database fail error
Jun 22nd, 2006
Hi folks,
I m using LMS 2.5. When i strt selftest in common service than it paases all test but database gives error. it is error"database.pl
FAIL Self Test Fail to query dfmFh.DbVersion, Error: Internal database error *** ERROR *** Assertion failed: 100909 (9.0.0.1383)
Error deleting transaction log file -- transaction rolled back (DBD: login failed)
Self Test Fail to query dfmFh.SYSTABLE, Error: Internal database error *** ERROR *** Assertion failed: 100909 (9.0.0.1383)
Error deleting transaction log file -- transaction rolled back (DBD: login failed)". Can anyone tell me how can i remove this error????????
thanks
Overall Rating: 4 (2 ratings)
Martin Ermel Fri, 06/23/2006 - 00:09
  • Blue, 1500 points or more
try to just reset the db Password for the FH db and then rerun the selftest
first you have to stop the processes
net stop crmdmgtd
cd to ..\CSCOpx\bin
then issue the following cmd:
.\perl dbpasswd.pl dsn=dfmFh npwd=
restart the processes:
net start crmdmgtd
rerun selftest
parvs_cmc Fri, 06/23/2006 - 01:47
hi mermel,
thanx for remedy, yes it worked, now my problem has solved but one more problem after this i m facing is that now network.pl is showing fail. it is showing "non existing domain""nslookupfailed".suggest me some idea abt this also.
thnx
