Warning message
Cisco 2800 Series and ISDN problems
Jun 23rd, 2006
Dears,
My company is using cisco routers as gateways conected through FXO and ISDN with Siemens HiPath PBX.
We have up and running twoo c2801 with ISND BRI coneted to PBX, but now we got more c2811 routers with ISDN BRI int. and I'm not enable to make calls through this devices.
Here you can see ISDN Status (which seams OK):
test#show isdn status
Global ISDN Switchtype = basic-qsig
ISDN BRI0/0/0 interface
******* Network side configuration *******
dsl 0, interface ISDN Switchtype = basic-net3
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 255, SAPI = 0, State = TEI_ASSIGNED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x80000003
ISDN BRI0/0/1 interface
dsl 1, interface ISDN Switchtype = basic-net3
Layer 1 Status:
ACTIVE
Layer 2 Status:
Layer 3 Status:
Active dsl 1 CCBs = 0
Total Allocated ISDN CCBs = 0
When I try to make calls from PBX then I get this ERROR from Debug Isdn Q931:
*Jun 23 10:14:22.743: ISDN BR0/0/1 Q931: RX <- SETUP pd = 8 callref = 0x01
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x83
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x0180, '108'
Plan:ISDN, Type:Unknown
*Jun 23 10:14:22.747: ISDN BR0/0/1 **ERROR**: CCBRI_Go: NO CCB Src->HOST call id 0xE, event 0x8 ces 1
*Jun 23 10:14:26.739: ISDN BR0/0/1 Q931: RX <- SETUP pd = 8 callref = 0x01
Standard = CCITT
Channel ID i = 0x83
*Jun 23 10:14:26.743: ISDN BR0/0/1 **ERROR**: CCBRI_Go: NO CCB Src->HOST call id 0xF, event 0x8 ces 1
*Jun 23 10:14:30.739: ISDN BR0/0/1 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x01
Cause i = 0x81E6 - Recovery on timer expiry
*Jun 23 10:14:30.739: ISDN BR0/0/1 **ERROR**: L3_BadPeerMsg: event 0x5A cr 0x81 callid 0x0
*Jun 23 10:14:30.883: ISDN BR0/0/1 Q931: RX <- SETUP pd = 8 callref = 0x01
Standard = CCITT
Channel ID i = 0x83
*Jun 23 10:14:30.883: ISDN BR0/0/1 **ERROR**: CC_CHAN_GetIdleChanbri: All channels busy
*Jun 23 10:14:30.887: ISDN BR0/0/1 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x81
Cause i = 0x82A2 - No circuit/channel available
*Jun 23 10:14:31.887: ISDN BR0/0/1 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x81
After this attempt both channels are getting BUSY.
Any idea about this issue?
Thanks in advance...
Nazmi
anup.anand Fri, 06/23/2006 - 04:53
  • Silver, 250 points or more
There is a problem at Layer 2
Layer 2 Status:
It should have been
Layer 2 Status:
TEI = 0, Ces = 255, SAPI = 0, State =MULTIPLE_FRAMES_ESTABLISHED
Please check to make sure the ISDN Switch type is correct. Check this link for more details on ISDN Layer 2 troubleshooting.
http://www.cisco.com/en/US/tech/tk801/tk379/technologies_tech_note09186a0080094b77.shtml
Also verify which device should be the network side, the PBX or the router and configure the other device to be the user side.
Anup
MEB-PR Mon, 06/26/2006 - 01:42
Thanks for Replay.
I made a mistake when copying isdn status.
I can make Layer 2 connection: (se below)
Global ISDN Switchtype = basic-net3
ISDN BRI0/1/0 interface
dsl 2, interface ISDN Switchtype = basic-net3
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 255, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
Active dsl 2 CCBs = 0
I noticed when Ces=255 it will not work.
I can manage somehow to make this work but ONLY when in LAYER 2 Ces=1.
When I change the router or ios or interface then it takes me hours to make it work and I still dont know what is going on.
Once again I manage every time to bring Layers UP (including Layer 2) but cannot make calls unless the Ces=1,
Any idea how to get Ces=1 ??????
Nazmi
kzeeshan Mon, 06/26/2006 - 03:24
  • Cisco Employee,
Please check if you are not hitting CSCei13743.
Otherwise check with your Telco. The error you are getting is because of no channel is available to make a call on. There could be several reasons like SPID configuration, connectivity, incorrcet config and lastly a software bug.
