How to show link usage off of a 6509 switch port in CatOS?
Jun 23rd, 2006
I want to find out the input / output data rate off of a switch port of a 6509 switch running in hybrid mode. What's the command for that in CatOS?
Something similar to "sh int GE3/1" in IOS to show the input / output rate off of the interface.
Gary
Overall Rating: 1 (1 ratings)
Anand Narayana Fri, 06/23/2006 - 08:56
  • Silver, 250 points or more
it is show port
eg. show port 4/1
this shows the details of the port activity which is equal to "show interface gigabit 0/1" to IOS command
how this helps
rate this post.
pciaccio Fri, 06/23/2006 - 09:57
You can also use the SHOW TOP command. It will show you the utilization of the port. It only shows you the top 10 talkers in the switch.UIf your port is not one of them it will not show it....
vladrac-ccna Fri, 06/23/2006 - 10:02
show port is far from similar show interface on IOS
show top all will help you,
Vlad
