Warning message
ip nat ?
Jun 23rd, 2006
how do you nat a 11.0.0.0/8 network to a 10.0.0.0/8 network in a cisco 877 router. ie 10.1.143.251 to 11.1.143.251 and so on. i am trying to nat a specific address in a 10. network over to the relative 11. network.
devang_etcom Fri, 06/23/2006 - 09:38
  • Gold, 750 points or more
it will be like this
ip nat inside source static 10.1.143.251 11.1.143.251
this is for enabling mapping of internal source address to global address
and
ip nat outside source static 11.1.143.251 10.1.143.251
this is for enabling mapping of global address to internal source address
hope this will help you
rate this post if it helps
regards
Devang
devang_etcom Fri, 06/23/2006 - 09:45
and yes remember to add ip natinside or ip nat outside on interface...
and this are some good link which will help you:
Basic NAT:
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080094831.shtml
Configuration:
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080094e77.shtml
regards
Devang
