WLSE Error
Jun 23rd, 2006
I am running WLSE 2.11. I just installed a 12.42ag series WAP as a WDS device, assuming it would work without double checking. RRRRrrr, I never do that, but lately I've had more work then I can deal with. We've been using the 1231. Anyways, when I perform a discovery, WLSE reports the 1242ag series WAP as an unsupported device. Can I do anything about this or do I have to go back to the 1231?
scottmac Fri, 06/23/2006 - 19:18
  • Green, 3000 points or more
Check the Download | Wireless page. Cisco "occasionally" comes out with device support updates that may include your 1242.
If that's the case, that'll save you from having to do a firmware update/replacement on the WLSE, which I believe would be your only other option.
Good Luck
Scott
ctmcse Sun, 06/25/2006 - 13:36
The 1242 should be supported - ensure that your SNMP object identifier is 'iso' else the WLSE cannot manage the device. HTH
rmushtaq Sun, 06/25/2006 - 21:48
  • Blue, 1500 points or more
Using the SNMP query tool under Admin->Connectivity Tools, what do the sysObjectId for this AP come back with?
markgreenwood Mon, 06/26/2006 - 06:26
You need to upgrade to 2.12 or 2.13 of the WLSE software to get support for the newer AP.
Trending Topics - Security & Network
