Integrated ISIS Problem
rmujeeb81
Hi All,
I have a Cisco 2610 Router having IOS version 12.2(29a). I want to run isis protocol on this router but unable to do this. When I enter " router isis " command in configuration mode then the prompt does not change to Router(config-router)# mode. Kindly help me in this regard.
Mujeeb
leonvd79
Level 4
Level 4
You need an enterprise feature set to run IS-IS. What is the full name of the image ? e.g."c2600-js-mz.122-29a.bin"
--Leon
* Please rate posts.
