Muticast problem, Need help on the one!
Jun 26th, 2006
  • Silver, 250 points or more
My distribution router are cat 6509-SUP720-PFC3A. One of my distribution bloc is giving access to many small building over fiber link. In each building, I have a pair of 4912G serving as building root(SPT also). They are connected together and access switch(3500XL or 3750) are connected to each of them.
My problem is that I'm not receiving any IGMP Query from the PIM-DR on ->ONE<- vlan. If I change the vlan of the port, it work's!. The config of the vlans interfaces on the two router is the same.
The router debug tell my that it's sending the query. If I sniff the host, it's receiving the data but never the query. The session timeout after 2-3 minutes. This is the only vlan with this problem.
leonvd79 Mon, 06/26/2006 - 21:29
Hello Dominic,
Have you checked if the IGMP snooping is enabled for that VLAN? I have seen many application fail because intermediate switches blocked propagation of IGMP query/join messages.
The fact that another VLAN is capable of receiving and sending IGMP query/join messages makes this doubtful. Can't harm to check it though.
Switch# show ip igmp snooping vlan x
--Leon
* Please rate posts.
dominic.caron Tue, 06/27/2006 - 04:30
The L2 switch are configure ok...cmgp or igmp.
I have two possible suspect...a host on the vlan is causing this or the L2 part of the SUP720 is not doing it's job. How do I troubleshoot the L2-SUP720
criss_noh Mon, 06/26/2006 - 22:35
I think SW does not work IGMP snooping, or does not know where IGMP query is from. i suggest you enable IGMP snooping or specify IGMP source IP address.
ex)
Switch(config)#ip igmp snooping querier ?
address IGMP querier source IP address
max-response-time IGMP querier maximum response time (sec)
query-interval IGMP querier query interval (sec)
tcn IGMP querier TCN related parameters
timer IGMP other querier timer
version IGMP version
dominic.caron Tue, 06/27/2006 - 04:20
Here is my interface configuration
interface Vlan82
description (FFG) Sciences giomatique Casault (diligui)
ip address X.X.82.2 255.255.255.0
ip access-group 171 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip pim dr-priority 10
ip pim sparse-mode
ip cgmp
standby 10 ip X.X.82.1
standby 10 timers 1 4
standby 10 priority 200
standby 10 preempt delay minimum 10
standby 10 track Port-channel13 75
standby 10 track Port-channel15 75
end
CSLDKNA#sh ip igmp snooping mrouter vlan 82
vlan ports
82 Po117,Router
Vlan82 is up, line protocol is up
Internet address is x.x.82.2/24
IGMP is enabled on interface
Current IGMP host version is 2
Current IGMP router version is 2
CGMP is enabled on interface
IGMP query interval is 60 seconds
IGMP querier timeout is 120 seconds
IGMP max query response time is 10 seconds
Last member query count is 2
Last member query response interval is 1000 ms
Inbound IGMP access group is not set
IGMP activity: 58 joins, 57 leaves
Multicast routing is enabled on interface
Multicast TTL threshold is 0
Multicast designated router (DR) is X.X.82.2 (this system)
IGMP querying router is X.X.82.2 (this system)
No multicast groups joined by this system
IGMP snooping is globally enabled
IGMP snooping is enabled on this interface
IGMP snooping fast-leave (for v2) is disabled and querier is disabled
IGMP snooping explicit-tracking is enabled
IGMP snooping last member query response interval is 1000 ms
IGMP snooping report-suppression is enabled
dominic.caron Tue, 06/27/2006 - 04:24
Should I do
ip igmp joint-group x.x.x.x
ip igmp snooping static xxxx.xxxx.xxxx int poXXX
