Warning message
wfr33man1 Fri, 07/07/2006 - 12:41
Aaron, I am trying to configure my Call manager to allow callers to dial a specified number (on my CM server), get a dial tone and dial a different number.
I'm not sure what this is called, but it's similiar to an unattended receptionist.
Do you know if this is possible within CM and, if so, how I would configure it?
William
thisisshanky Fri, 07/07/2006 - 21:11
  • Purple, 4500 points or more
William,
What you are looking for is a auto attendant. You will need Extended services and CRA installed (not IPCC). The cd comes with the callmanager discs. you can setup basic auto attendant in callmanager with this.
wfr33man1 Fri, 07/07/2006 - 21:31
Thanks for your reply. I will look into installing these features from the CM cd's that I have.
Will this act as an unattended call routing mechanism?
I'd like for a caller to be able to call a number within my CM and have that number be directed to an outside line and allow that caller to dial any number that they choose to.
William
Lee_Barrell Tue, 09/13/2011 - 08:46
Yes we have 15 devices and we are ruinning 6.1 software and we can only get 9 devices to register at any one time!
I've also tried to get the Multicasting part working using an ephone-dn, with the feed ip cmd as follows;
ephone-dn 310
name paging zone 1
feed ip 239.1.1.100 port 8560
This does not work, I have multicast working on the network so far with paging-dn's and MOH working fine!
Lee
PS. Please let us know how your TAC case works out!!
