Warning message
beta vpn for vista
b.hsu Mon, 07/03/2006 - 06:56
  • Silver, 250 points or more
Turning off aaa authentication http-secure-client makes it work.It may also fail to understand TLS extensions.IE7 not exchanging the correct SSL keys with the PIX code.Try enabling Stateful firewall of the vpn client using the following settings options stateful firewall.
