Upgrading from PIX 7.0(1) to 7.2(1)
Answered Question
Jun 27th, 2006
I'm reading the release notes for 7.2(1) but it has a lot of errors (keeps referring to 7.1 instead of 7.2). My question is - can I go straight from 7.0(1) to 7.2(1) and do I need to upgrade ASDM first? (currently running 5.02). Is it a matter of just replacing the two .bin files and rebooting (like with the older versions) or do I need to do something else?
Thanks in advance!
Correct Answer by grant.maynard about 11 years 1 month ago
you probably won't have enough flash for two images and an ASDM.
1. delete asdm image - "delete flash:/asdm..."
2. copy tftp flash:
3. change config to "boot system flash:/pix721.bin"
4. reload
5. if that's ok then remove old image - "delete flash:/pix70x.bin"
6. tftp new asdm
7. change config to "asdm image flash:/asdm.bin"
Overall Rating: 5 (2 ratings)
grant.maynard Tue, 06/27/2006 - 08:23
  • Silver, 250 points or more
You can go 7.0(x) to 7.2(1). I'd upgrade PIX image first from CLI. Make sure boot pointer is correct.
ph0enix Tue, 06/27/2006 - 08:30
So I'm going to:
1. replace the PIX .bin
2 change the config to "boot system flash:/pix721.bin"
3. reload
4. replace the ASDM .bin
5. reload
Correct?
Thanks!
Correct Answer
grant.maynard Tue, 06/27/2006 - 15:27
2. copy tftp flash:
4. reload
6. tftp new asdm
