Warning message
about BGP dual/multihomed
Jun 27th, 2006
  • Silver, 250 points or more
Hi folks,
Well, I'm a little bit confused about all solution for bgp dual/multihomed load sharing/balancing:
1- MED / local pref
2- 'maximum-paths' and 'bgp dmzlink-bw'
3- OER
Could you help me to understand better?
Any advice will be appreciated
Andrea
aghaznavi Mon, 07/03/2006 - 10:40
Med or metric attribute is used for specifying a path for a prefix into our autonomous system.
Maximum- paths is the command with which we will specify how many routes should be installed in the bgp table to a particular destination. By default bgp installs only one path in it's table to a particular destination.
