How to restore a backup config on PIX 6.3
corey.mckinney
Using PDM I copied the running-config to a TFTP server. How do I restore that back on to the PIX with ver 6.3?
5 Replies 5
ph0enix
copy tftp flash
That won't work with 6.3. When you use that command, you can only copy it as an ios image or the pdm file. You can't copy the config that way.
in this case, hook it up to a console, open the config in a text editor and paste it line by line.
Nevermind!!!
I figured it out. Inside 'config t' you use the command 'config net x.x.x.x:filename'
Thanks anyway for responding.
Not very intuitive but good to know.
