Warning message
WLAN design
Jun 28th, 2006
I'm conteplating taking on a project to install a wlan for a 70,000 sq ft hall. The second requirement is that it will need to support a couple hundred simultaenous users. My question is, what would be the most cost effective solution for such a wlan? I was thinking using a 4100 with a few APs. What do you guys recommend. Also something that wouldn't be a pain to configure. I'm farily new to wireless on such a scale..
thank you.
a.kiprawih Fri, 06/30/2006 - 10:33
  • Gold, 750 points or more
Try AP1100. It uses Lightweight Access Point Protocol (LWAPP), and can be managed by Cisco wireless LAN controllers. It's fairly easy to configure & manage. Comes with built-in antenna.
http://www.cisco.com/en/US/products/hw/wireless/ps4570/products_data_sheet09186a00800f9ea7.html
OR, try AP1200 Series with LWAPP image if you need to use external antenna. This model can be ordered with IOS image. Make sure the product no has 'LAP', e.g AIR-LAP1231G-x-K9.
http://www.cisco.com/en/US/products/hw/wireless/ps430/products_data_sheet0900aecd801b91d4.html
The no of APs will determine model of WLAN Controller to use as it goes by no of APs.
http://www.cisco.com/en/US/products/ps6366/products_data_sheet0900aecd802570b0.html
Rgds,
AK
pawan_pardeshi Fri, 07/21/2006 - 00:28
Dear marekkurowski
I have Many suggestions and am very keen to help you to design WLAN but are u using only Cisco product or any other also produtcs ? pls let me know.
Next you have done site survey mean you have data -what is your application ?how many users at time? security issues ? foreign interfernce issues ?
pls provide me data , i would like to suggest many things.
PAWAN P PARDESHI
SENIOR WIRELESS NETWORK ENGINEER
MICROSENSE INDIA LTD
MUMBAI INDIA
