Warning message
Network assistant and error
Jun 28th, 2006
I have cat 2950 and I am trying to use Network assistant to monitor the network and check the configuration of the switches. I currently get IOS command not found when I use the network discovery tool to locat the switches. any ideas? will the CNA also locate cisco routers?
nhabib Wed, 06/28/2006 - 16:03
  • Red, 2250 points or more
With CNA, it is critical to make sure you have the proper IOS version.
Check the CNA supportlist for devices and IOS versions.
