Warning message
MGCP w/ SRST config to not lose ports
Jun 28th, 2006
I have a router running MGCP with H323 fallback for SRST. When resetting the gateway through CallManager or when the router reregisters, the ports disappear from the dial-peers.
We used to pull out the CCM-MANAGER CONFIG command to help aleviate this, but now with the latest CallManager versions and router IOSes, some things no longer work right when you remove the CONFIG command.
Is there a trick to maintain the MGCP/H323-SRST config, keep the CONFIG command, and NOT lose the ports out of the dial-peers?
Sascha Monteiro Wed, 06/28/2006 - 18:59
  • Silver, 250 points or more
can you post your config (mgcp/ccm-manager/dial-peer/callmanager-fallback)
it sounds very unusual tho
keep in mind that you will never retain ective calls on failover, as L3 is backhauled to CCM
Robert Milanovich Wed, 07/12/2006 - 13:12
The problem is this:
Lets say you have a PRI at 0/0
For SRST/H323 to push calls out of the PRI, you have to have a dial-peer that matches something likt 9T and pushes the calls out the PRI with a PORT 0/0:23 command in the dial peer.
When the MGCP gateway registers with CCM, CCM will usually reconfigure all the ports... which you can see the reconfig on the console as all the ports go down and then up.
When the PRI gets reconfigured, the PORT 0/0:23 line gets removed out of the dial-peer used for the outbound calls in SRST mode.
Then when the gateway does actually assume the SRST role, it doesn't have a PORT command within the dial-peer for the 9T pattern and all outbound calls fail.
Brian Carscadden Wed, 07/12/2006 - 13:35
This may be related to a problem I had some time ago. Delete, then re-add all your H.323 dial-peers so that they appear after the MGCP-registered dial-peers.
soupseven Sun, 09/10/2006 - 20:45
Hi, rmilanovich,
Have you figured out this problem? I met the same problem as I configured my voice gateway to support SRST. I configured some dial peers to especially support 4 digit dialing and external dialing without waiting for inter-digit timeout. But I will lose port info each time I reload the gateway or reset MGCP.
Please help if you got the answer. I have been working on this for a couple of days and nights.
Many thanks!
Robert Milanovich Sun, 09/10/2006 - 21:33
My solution to this "problem" is to not use MGCP on any gateway that needs to do SRST. Hopefully someone will come up with something.
