Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1926083members
1237441discussions
Community Activity
Redundancy Over VSAT Link
Hi, we have a WAN and VSAT connection to one of the site. WAN is primary and VSAT is secondary link.We have dedicated router for WAN and VSAT. VSAT link is connected to one of the LAN access switch.Could you please help me, what kind of configuration...
inhamit by Level 1
  • 3 Views
  • 0 replies
WebEx Audio not working on CarPlay
a. I initiate a WebEx call on my phone (through WebEx App).  Audio is working fine.  I then plug in the USBc cable into my phone, CarPlay comes up on the car display.  I see the call UI on the car display, but no audiob. I initiate a WebEx call from ...
bnsrini by Level 1
  • 243 Views
  • 3 replies
Resolved! Cisco Switch 1000 24port にリプレースしてからネット接続が遅くなった。
<主訴>日中に20%程度のPCがネットに接続できなくなる。アクセスできても、遅い。<社内システム概要>-2024年2月にNetgearのL3スイッチから、Cisco Switch 1000 24port (1Gbpsのポート)にリプレース-8Fフロアのビルで従業員 500名、PC 500台となる。-Cisco Swich 1000 24をL3 Core Switchとして運用している。-スタティックルーティングを利用している。(RIPやOSPFなどは使っていない)-Coreスイッチは、1台構成と...
k-system by Level 1
  • 125 Views
  • 1 replies
QOS for a Destination-ip in Cisco IOSXE
Hi All,We have a URL which resolves to particular public ip and performance of that website is slow than expected from our office . We have a P2P link from office to DataCentre and from DataCentre it exits to internet. We observed the performance was...
WLC 9800 Process iosd Eror
hello,i'm running wlc9800-40 17.6.4 version and i'v got this errorSeverityProcess NameMessageCriticaliosdApr 10 23:47:04.326: %IOSXE_QFP-2-LOAD_RECOVER: Slot: 0, QFP:0, Load 45% recovered.5 secs traffic rate on QFP: Total Input: 13034 pps (13.0 kpps)...
RoeyF by Level 1
  • 245 Views
  • 13 replies
9800 Guest Anchor Design
I am trying to understand Guest Anchoring with the 9800 Controllers. In the 5500 series WLCs you had to access the WMI from the inside network through the firewall to the Anchor Controller Mgmt Vlan on a DMZ.  Then create another sub-interface on the...
VRRP issue
Facing issue with VRRP, when upstream router5 initiate traffic for downstream router6 then return traffic is not following VRRP VIP as Gateway. In my case switch2 is master and switch3 is standby.If Router6 initiate the traffic then VRRP working fine...
Recommendation Software ISE
Hi EveryoneOur client for ISE software still uses version 2.6 with pach 10,We will upgrade the software to 3.1 with patch 8, please provide a recommendation link from CiscoI'm afraid that if I downloaded it wrong it would have fatal consequencesThank...
Why VLANs are not being shown?
Greetings!So I was practicing to configure VTP and VLANs. For a start, I created 3 switches (only 2 being turned on). The trunks are working fine as the switches are able to acquire an IP addresses via dhcp from a dedicated router and vtp appears to ...
turtle666 by Level 1
  • 52 Views
  • 1 replies
Alternating ring
Our old work phones would take turns around the room. I don't think it was called hunt group, but once logged in to your group/extension...it would go around the room on whose turn it was to answer. Is there a way to do that? Thanks
Simple SSH Connection 9400 Not Working
Is there something different about configuring SSH on a 9407 with a C9400-SUP-1?  Currently there's no configuration on the device except for an IP address on the management port and ssh.  I've gone through the same procedures we've always used and v...
Catalyst 9000 シリーズスイッチ set ip next-hop verify-availability は非サポート
Catalyst 9000 シリーズスイッチと結線された対向機器の起動時等に、対向機器の不具合や実装により、Catalyst 9000 シリーズスイッチが PBR で使用しているインターフェースが対向機器の起動処理中アップしてしまい、この事に起因しPBR が動作してしまう事により、起動途中のためトラフィック転送ができない対向機器にトラフィックが転送されてしまうようなケースがあります。 Catalyst 9000 シリーズスイッチの PBR では、set ip next-hop verify-a...
