Warning message
FXO Ports
Jun 29th, 2006
I have a 2811 router that I need to install a 4 port FXO card. (VIC2-4FXO) The card is support in the HWIC slot according to Cisco, I do see it when I do a Show Version however I do not see the ports in the runnning config.
adabarno Thu, 06/29/2006 - 09:24
I have the following IOS:
(C2800NM-ADVENTERPRISEK9-M), Version 12.4(9)T
a.gooding Mon, 07/03/2006 - 12:00
  • Bronze, 100 points or more
am,
youre seeing in the running config, voice-card X right? might be voice-card 1 or something like that,
configure you codec to suite and issue a no shut. the voice ports should then be up
pedro6161 Wed, 09/13/2006 - 21:23
i have problem like that so i'm trying change my IOS but if i see in running config just show voice-card 0 and i not see voice-port X. If i restart my router, in bootrap i see 4 Voice Port FXO but i can't see voice-port in running config so i can't configure voice-port to up
