Warning message
Problem with 7.0 ASA
Jun 30th, 2006
Mister
I have a problem with 7.0 ASA .
I have a customer making a VPN Tunnel from inside Network . I am making PAT .
The VPN IPSEC with Ciscp VPN Client is succesfull , but the traffic don?t pass .
I only see encrypted packets , but no decrypted packets .
In 6.3 , I set the command "sysopt ipsec pl-compatible " , but in 7.0 , this command is deprecated .
I had to configure a static for my PC . The VPN traffic functioned , but this is not the better solution .
How could I resolve this with PAT but not NAT STATIC ?
Best Regards
froggy3132000 Sat, 07/01/2006 - 06:37
  • Bronze, 100 points or more
Are the trying to initiate a remote-access connection from inside to your ASA? or to a VPN over the internet?
I would assume they are trying to connect to a VPN other than yours, in that case you would need to enable
isakmp nat-traversal
