Voice VLAN on 3550
Jul 2nd, 2006
Does anyone know the correct way to configure a voice port on Cisco 3550? Cisco seem to use different config on every switch family.. it is a bit confusing..
eg: Voice vlan:100 with 802.1Q Frames, data vlan: 50.
it this the correct config??
interface FastEthernet0/10
switchport access vlan 50
switchport mode access
switchport voice vlan 100
spanning-tree portfast
also, how do config the switch if voice vlan use 802.1p Priority-Tagged Frames?
thanks
regards,
sean
Overall Rating: 3.5 (2 ratings)
SCOTT JORDAN Mon, 07/03/2006 - 05:31
Try this
Configure auto QOS to use correct DSCP values
This has voice vlan in 100 and data in default vlan(1)
duplex full
speed 100
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape 10 0 0 0
mls qos trust device cisco-phone
mls qos trust cos
auto qos voip cisco-phone
fred.s.mollenkopf Mon, 07/03/2006 - 05:40
  • Gold, 750 points or more
Sean,
Here is the link for configuring the 3550 with Priority-Tagged Frames. Above configuration is correct with the exception of the QoS in the below link. Also as a precaution I usually turn on Portfast BPDUguard on all portfast ports to insure I have no rogue switches plug in.
http://www.cisco.com/en/US/products/hw/switches/ps646/products_configuration_guide_chapter09186a0080115951.html#xtocid7
Here is the command for BPDUGuard
Spanning-tree bpduguard enable
Please rate the posts
Fred
ekhoo Mon, 07/03/2006 - 06:51
Many Thanks Jordan and Fred... i finally understand the way to configure voice port on dot1 voice port.
however, the "dot1p" voice port use native VLAN (VLAN 0) to carry all traffic..
what would be the config if we need to run the voice & data on different vlan eg, vlan 100 instead of native.
many thanks
Sean
fred.s.mollenkopf Mon, 07/03/2006 - 08:15
Sean,
I'm kinda lost with what you are trying to achieve but I'm gonna throw out my thoughts.
1. When configured with switchport access command and switchport voice command, dot1q and dot1p should work in tandem. Phones will tag COS 3 & 5 based off CM configuration and will be trusted by the switchport with the appropriate command. Access port will mark down to 0. Policy-maps can be used on the 3550 to match and set traffic from the PC. See QoS SRND. link below.
http://www.cisco.com/application/pdf/en/us/guest/netsol/ns432/c649/ccmigration_09186a008049b062.pdf
2. If your goal is to have PC & Voice on the same vlan then possible try this. Create a trunk port on switch. Native vlan will be 1. Prune or restrict only 1 vlan (or different native if allowed). See if both PC and Voice will come over on the single vlan. Alternatively set the native vlan to 100. Not sure if 3550 allows change of Native vlan. Apply trust cos statement to trunk port. I know for a fact that an Ip phone will come up on a trunk port but I've never really researched much into how the vlans ultimately were configured as it was a lab test awhile back.
Hope this helps
Fred
Daniele Giordano Sat, 07/08/2006 - 00:52
This is my configuration:
switchport trunk native vlan 50 ****(data vlan)
switchport trunk allowed vlan 50,100
switchport mode trunk
switchport voice vlan 100 ****(vocie vlan)
service poliy input .......
mls qos cos override
spanning-tree bpdufilter disable
spanning-tree bpduguard enable
This config work with device that support 802.1Q trunk and CDP protocol like CISCO ATA or CISCO IP Phone.
ekhoo Sat, 07/08/2006 - 09:45
Thanks Giordano. I have poked around and i think I got the the correct config for "dot1q" frame type voice config with "switchport mode access"...
As you can see the show parser below.. Cisco has the template for voice port configuration and it has been set to "mode access" instead of trunk.
I think you only use the "mode trunk" configuration on the old Cisco switches....
SW1#sh parser macro name cisco-phone
Macro name : cisco-phone
Macro type : default interface
# Cisco IP phone + desktop template
# macro keywords $access_vlan $voice_vlan
# VoIP enabled interface - Enable data VLAN
# and voice VLAN
# Recommended value for access vlan should not be 1
switchport access vlan $access_vlan
# Update the Voice VLAN value which should be
# different from data VLAN
# Recommended value for voice vlan should not be 1
switchport voice vlan $voice_vlan
# Enable port security limiting port to a 3 MAC
# addressess -- One for desktop and two for phone
switchport port-security
switchport port-security maximum 3
# Ensure port-security age is greater than one minute
# and use inactivity timer
switchport port-security violation restrict
switchport port-security aging time 2
switchport port-security aging type inactivity
# Enable auto-qos to extend trust to attached Cisco phone
# Configure port as an edge network port
