Warning message
irisrios Fri, 07/07/2006 - 12:41
  • Silver, 250 points or more
The first task you have to perform to enable CLNS routing is to assign addresses or NETs for your domains and areas. The domain address uniquely identifies the routing domain. All routers within a given domain are given the same domain address. Within each routing domain, you can set up one or more areas. Determine which routers are to be assigned to which areas.Refer
http://www.cisco.com/en/US/products/sw/iosswrel/ps1818/products_configuration_guide_chapter09186a00800878b7.html for more info.
