Warning message
Help with 871w WLAN & VLANs
Jul 4th, 2006
Hi! I think I'm too stupid for this...
I have a 871w with IOS c870-advipservicesk9-mz.124-9.T.bin. I'd like to have a config consisting of 4 VLANs: eth-priv, eth-guest, wlan-priv and wlan-guest. The *-guest vlans should only be able to get into the internet, not in my *-priv vlans. I want to use routing and ACLs, so I don't want bridging configured. All clients should get their IPs by DHCP, because my provider gives me my outer IP by DHCP, including DNS-server to use. I have the ethernet-vlans working fine, but can't get the hang of the wireless vlans...
Can someone point me to a config which does the things I want? Just the basics, I hope I can guess the details...
Thanx in advance!
Overall Rating: 5 (1 ratings)
dbakula01 Wed, 07/05/2006 - 08:57
as far as i know you need the bridging configured to get the puppy to work. i do not run multiple vlans but see if my config helps you
hostname xxxxxx
boot-start-marker
boot-end-marker
no logging buffered
enable password xxxxx
username admin password 0 xxxxxxxx
no aaa new-model
ip subnet-zero
ip cef
ip dhcp excluded-address xxxxxxxx
ip dhcp pool dcp
network xxxxxxxx 255.255.255.0
domain-name dcpartners.com
dns-server xxxxxxxx
default-router xxxxxxxx
ip dhcp pool xxxxxxxx
ip name-server xxxxxxxx
no ftp-server write-enable
bridge irb
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
ip address dhcp
duplex auto
speed auto
interface Dot11Radio0
no ip address
encryption vlan 1 mode ciphers tkip
ssid xxxxxxxx
vlan 1
authentication open
authentication key-management wpa
wpa-psk ascii 0 xxxxxxxx
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
channel 2437
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
bridge-group 1
interface BVI1
ip address xxxxxxxx 255.255.255.0
no ip http server
no ip http secure-server
ip nat pool dcp xxxxxxxx netmask 255.255.255.248
access-list 15 permit 192.168.1.0 0.0.0.255
access-list 15 permit 0.0.0.0 255.255.255.0
access-list 100 permit ip host xxxxxxxx 192.168.1.0 0.0.0.255
access-list 110 permit ip 192.168.199.0 0.0.0.255 192.168.1.0 0.0.0.255
control-plane
bridge 1 route ip
line con 0
no modem enable
transport preferred all
transport output all
line aux 0
line vty 0 4
login
transport input all
scheduler max-task-time 5000
end
