Warning message
CCM 4.1(3)sr3a different ring tone for different line
Jul 4th, 2006
Hi there,
I've got a dual line 7941 phone and would like to configure different ring tone for each of the lines. eg. I've got ext 100 and 101 on my phone. i would like the phone to ring differently when a call comes into 100 and 101 so i can know just by the ring tone which number has been called.
Can anybody help?
Cheers,
Jesminder
Overall Rating: 3 (1 ratings)
fred.s.mollenkopf Wed, 07/05/2006 - 11:13
  • Gold, 750 points or more
Jesminder,
Unfortunately ring tones are configured at a phone level. In order to do this you need to go to the phone, push the settings button, select ring type. From there you will get a menu. Line 1 of the menu is the default ring. Line 2 and on corresponding to your line numbers in order. So if you want CallManager line 2 to be a different ring tone then you will select line 3 from the ring type menu, it should have the extension number next to it.
There also might be a way to set it via the web interface. You would want to post in the Ip Communications - Ip Phone services for end users forum.
Please rate any helpful posts
Fred
