Warning message
router as a frame relay simulator
Answered Question
Jul 6th, 2006
hello,
how can i configure a router to be a frame relay switch?
I have 3 1720 routers (A, B and C).
thanks
Correct Answer by leonvd79 about 11 years 1 month ago
You can do so by entering the command "frame-relay switching" in global configuration mode.
Example
interface Serial0
encapsulation frame-relay
frame-relay intf-type dce
frame-relay route 102 Serial1 201
clock rate 72000
no shut
interface Serial1
frame-relay route 201 Serial0 102
clock rate 72000
no shut
Refer to the configuration guide for more information.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fwan_c/wcffrely.htm#wp1055601
--Leon
* Please rate posts.
Overall Rating: 2.5 (2 ratings)
Correct Answer
leonvd79 Thu, 07/06/2006 - 02:53
  • Silver, 250 points or more
Example
interface Serial0
clock rate 72000
no shut
interface Serial1
clock rate 72000
no shut
--Leon
