Warning message
AJAZ NAWAZ Thu, 07/06/2006 - 03:13
  • Silver, 250 points or more
Carl,
In short the answer to your qtn in 'No' if both the hosts share a common communication segment. So, a router will not be required.
The reason for this is that 172.17.51.1 and 172.17.51.10 both fall into the subnet range of /24 and /16.
hth,
Ajaz Nawaz
farkascsgy Thu, 07/06/2006 - 03:20
So the first subnet is 172.17.51.0-172.17.51.255 (including subnet network address and subnet broadcast) the second subnet is from 172.17.0.0-172.17.255.255.
If the two PC directly connected via crossover cable (or connect to the same LAN segment) and the second PC has address from the first IP range (not the same as the first PC) they can communicate without router.
Anyway the two IP ranges are overlaped each other as you can see above!
bye
FCS
Rate me if I helped.
desai.jaideep Thu, 07/06/2006 - 03:40
  • Gold, 750 points or more
Shoudn't your question be "will 172.17.51.1/24 will communicate with 172.17.52.1/16"?
I believe your question is above.....:)
JD
