Warning message
3560 CBWFQ
Jul 6th, 2006
I am trying to implement CBWFQ on a cisoc 3560 switch.
One switch has Version 12.1(19r)EA1b and it does not work, when you enter in one of the interfaces service policy output test-voice you get the message Warning: Assigning a policy map to the output side of an interface not supported.
However, On another customers site this works on a lower version of software.
Has anyone else seen this and is there a workaround without upgrading or downgrading the ios ???
Aaron Harrison Thu, 07/06/2006 - 06:10
  • Community Spotlight Award,
    Member's Choice, May 2015
The thing to consider here is that although commands appear in the CLI you can't necessarily use them...
On a router you construct a policy-map with any number of classes in it, and the prioritisation is done in software.
On a switch, you have a finite number of queues (4, or 3 + 1 PQ). To manage these queues you don't use a policy map, but configure the srr-queue commands per interface (and also the various maps under the global 'mls qos...' commands.
Policy-maps on the switch are used only for inbound classification of traffic, remarking, and a couple of other functions such as policing, like so:
policy-map IPPHONE+PC+CRITICAL
class VVLAN-VOICE
set dscp ef
police 128000 8000 exceed-action drop
class VVLAN-ANY
set dscp af31
police 32000 8000 exceed-action policed-dscp-transmit
class DVLAN-VIDEOCONFERENCE
set dscp af41
police 496000 8000 exceed-action policed-dscp-transmit
class DVLAN-CRITICAL
police 10000000 8000 exceed-action policed-dscp-transmit
set dscp af21
class class-default
set dscp default
I'm guessing that the earlier version of IOS you mentioned simply didn't have the warning message - CBWFQ just isn't available on the 3560s.
Have a look at the QoS section of the manual - it's not a clear or simple subject, so feel free to post back any questions:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3560/12225see/scg/swqos.htm
Aaron
Please rate helpful posts....
