Warning message
Catalyst 4500, supervisor II+, EIGRP
Jul 7th, 2006
We're bought a catalyst 4500 sup II+ with image cat4000-i9s-mz.122-25.EWA4.bin
In feature navigator isn't anything about EIGRP in this image, but in CLI I may configure EIGRP.
How is that possible?
thx
Overall Rating: 1.5 (2 ratings)
marekduba Fri, 07/07/2006 - 01:33
Yeah, i saw this about EIGRP stub... but if I write sh run command, there's no line with eigrp stub in router eigrp section.
Is the eigrp stub command on by default? And how can I check the stub settings?
marekduba Sun, 07/09/2006 - 03:49
So, there is routing proto's that I can configure in CLI... How is that possible?
bgp Border Gateway Protocol (BGP)
egp Exterior Gateway Protocol (EGP)
eigrp Enhanced Interior Gateway Routing Protocol (EIGRP)
isis ISO IS-IS
iso-igrp IGRP for OSI networks
mobile Mobile routes
odr On Demand stub Routes
ospf Open Shortest Path First (OSPF)
rip Routing Information Protocol (RIP)
slaurin Tue, 07/11/2006 - 05:49
Good morning,
Your image is IP BASE and it does not support EIGRP to be processed in hardware. It is going to work, but the switch will kick EIGRP out of the CPU.
You would need to download an ENHANCED L3 image to have native EIGRP support. Look for "is5s-mz" in the image, for example
cat4000-i5s-mz.122-25.EWA6.bin>>>>ENHANCED L3 (OSPF,EIGRP,IS-IS)
Simon Laurin
glen.grant Mon, 07/17/2006 - 12:52
  • Purple, 4500 points or more
You will also see that the commands to run ospf and even bgp are in there and will work in a lab situation but also are not supported .
