Warning message
syslog
ariela Fri, 07/07/2006 - 23:17
  • Silver, 250 points or more
fast answer:
on your cisco try something like that:
logging buffered 16384 debugging
no logging console
no logging monitor
logging trap debugging
logging source-interface (FastEthernet0/0)
logging (unix ip)
and on your unix management server (syslog.conf):
local7.debugging /var/log/cisco.log
more info here:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/ffun_c/fcfprt3/fcf013.htm#wp1001168
Andrea
abhishek_nandavat Fri, 07/07/2006 - 23:20
Hi!
You need to first build a server and then install some syslogging software on that.(Kiwi syslog is the best and its available for free!!!)
Then you need to add this server as the syslog server in all the devices from which you want logs to be stored.
On all the devices from which you want logs, enter the following commands:
- enable
- configure terminal
- logging host a.b.c.d
- logging trap '0-7'
logging level 0 is the most severe and logging level 7 is the lowest in severity.
You can also configure services so that all your logs have a time stamp with the date and time.
Enter the following commands:
- enable
- service timestamps log datetime
For more please refer the following link -->
http://www.cisco.com/en/US/products/hw/switches/ps646/products_configuration_guide_chapter09186a00801f0a4e.html#1031634
Download Kiwi syslog daemon from the following link-->
http://www.kiwisyslog.com/php/download.php?syslogdV8_kiwitools&v=8.0.2
Hope this helps.
Please rate all posts.
AbhisheK
steve_miller Sat, 07/08/2006 - 01:15
Kiwi is not the best but may be the simplest for you to get up and running. Most every unix variant has a syslog daemon that you can use to store or forward syslog messages.
I would say that syslog-ng is the best free syslog server available if you are looking for something that is amazingly configurable and unix based. It is an absolutely phenomenal syslogd replacement.
