ciscoworks
Jul 9th, 2006
hi everybody
could you pls tell me if i want install ciscoworks on my pc,how much memory needed? or what would be the CHARACTERISTICS of my pc?
could you interduce me self -study docs about ciscoworks?
thanks
Overall Rating: 4.5 (2 ratings)
farkascsgy Sun, 07/09/2006 - 02:02
  • Silver, 250 points or more
System hardware
IBM PC-compatible system with 500 MHz Intel Pentium processor.
- Color monitor.
- CD-ROM drive.
Memory (RAM) 512 MB.
Available drive space
1. Do not install CiscoWorks SNMS 1.5 on a FAT file system.
- 2 GB.
- Paging file space equal to double the amount of memory (RAM).
For example, if your system has 512 MB of RAM, you need 1024 MB of page file.
- NTFS file system required for secure operation.
- At least 16 MB in Windows temporary directory (%TEMP%).
System software
2. You cannot install CiscoWorks SNMS on a system configured as a primary or backup domain controller.
Do not install CiscoWorks SNMS in an encrypted directory. CiscoWorks SNMS does not support directory encryption.
- Windows 2003 Server (Standard and Enterprise Edition).
- Windows 2000 Professional with Service Pack 4.
- Windows 2000 Professional and Server with Service Pack 3.
- ODBC Driver Manager 3.5.10.
CiscoWorks SNMS 1.5 supports only US-English and Japanese versions of
Windows Operating Systems. It does not support any other language version. Set
the default locale to US-English for US-English version and Japanese for
Japanese version.
This is the server site requirement...
bye
FCS
Please rate me if I helped.
miheg Sun, 07/09/2006 - 12:04
  • Gold, 750 points or more
I never managed to install SNMS on 2003. The installation routine doesn't want to install on such OS
Is there something you can do the fool the install routine?
Cheers,
Michel
Joe Clarke Sun, 07/09/2006 - 16:49
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You need SNMS 1.5.1 (1.5 doesn't work on 2003). The 1.5.1 installer should not need any "fooling" to work.
However, I didn't see SNMS mentioned at all in the original question. Typically, when one talks about CiscoWorks, they are referring to LMS. LMS requires at least 2 GB of RAM and 4 GB of swap just to start (without managing any devices). If you plan on installing the whole bundle on one server, you need a multi-CPU machine.
The best all-in-one page for all the CiscoWorks bundles is http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/cw2000_b/index.htm . For specific CiscoWorks applications, see http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/index.htm . All of the server requirements will be listed there. For good white papers on LMS, see http://www.cisco.com/en/US/customer/products/sw/cscowork/ps2425/prod_white_papers_list.html .
miheg Sun, 07/09/2006 - 22:05
True, LMS is typical, SNMS is not.
But when I saw SNMS and win2k3 mentioned I recalled it didn't work on that platform.
1.5.1 installer? Isn't this 1.5.1 like an SP that you install ontop of the SNMS? There was something on the SNMS CD called 1.5.1 Update K9. I guess if it is not an SP then I was given the wrong CD to install.
Cheers,
Michel
Joe Clarke Mon, 07/10/2006 - 05:36
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You need to order CWSNM-MAR05-SR-K9 which may be a free upgrade available at http://www.cisco.com/upgrade/ . This should install directly onto Windows 2003.
