Warning message
IDS 4235 Appliance "Error: While loading shared libraries"
Jul 9th, 2006
There is a problem with IDS 4235 at login the error report is pasted as follows
sensor login: cisco
Password:
Last login: Wed Jul 5 20:54:42 on ttyS0
***NOTICE***
This product contains cryptographic features and is subject to United States
and local country laws governing import, export, transfer and use. Delivery
of Cisco cryptographic products does not imply third-party authority to import,
export, distribute or use encryption. Importers, exporters, distributors and
users are responsible for compliance with U.S. and local country laws. By using
this product you agree to comply with applicable laws and regulations. If you
are unable to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto
[email protected].
-cidcli: error while loading shared libraries: libstlport_gcc.4.5.so: cannot open shared object file: No such file or directory
I tried recovering the appliance image through direct monitor and keyboard connected to IDS as well through Console the same login prompt appears at every correct login credentials entered need a solution to this problem
Rgds
Ahmed
