Warning message
show ip pim neighbor
Jul 9th, 2006
I got problem with PIM as when I run "show ip pim nei" command in specific vlan:
SSP-GCORTMSFC-02#sh ip pim nei vlan188
PIM Neighbor Table
Neighbor Address Interface Uptime Expires Ver Mode
11.202.167.126 Vlan188 3d01h 00:01:30 v2 (DR)
10.246.28.124 Vlan188 7w0d 00:01:43 v2
but actually, I don't have any IP address for 11.202.167.126!
SSP-GCORTMSFC-02#sh ru int vlan188
Building configuration...
Current configuration : 433 bytes
interface Vlan188
description SSP3 Closet Room 2 (Seg188)
ip address 165.202.188.125 255.255.255.0 secondary
ip address 10.246.28.125 255.255.252.0
ip helper-address 165.202.20.177
ip helper-address 165.202.19.177
no ip redirects
no ip unreachables
no ip proxy-arp
ip pim sparse-mode
no ip mroute-cache
standby 28 priority 110 preempt delay 120
standby 28 ip 10.246.28.126
standby 28 ip 165.202.188.126 secondary
end
Can anyone help me to find out the problem? Multicast at vlan188 doesn't work and I suspect that's the root of the problem co's the PIM nei & DR is wrong.
Thanks in advance
Overall Rating: 1 (1 ratings)
leonvd79 Tue, 07/11/2006 - 02:01
  • Silver, 250 points or more
When you enable PIM on a interface the router starts sending hello messages every 5 seconds. A router on your network is selected a designated router which has the IP address 11.202.167.126.
To see where this information originated use the "debug ip pim hello" to see who your neighbors really are.
--Leon
* Please rate posts.
romccallum Wed, 07/12/2006 - 05:47
or do a show ip pim interface vlan xxx and that will show you some more detail.
OR just telnet to the 11 interface and find out what it is ;-)
