Warning message
RSA Authentication Manager and CiscoSecure ACS.
I'm using two ACS 4 servers to authenticate and configure vpn remote users. Now I'm trying to use the RSA token server: install primary and replica server. All seem ok.
So I can authenticate successfully on primary ACS, but when I try on secondary ACS (RSA replica) I can see "Node verification failed" on RSA log.
Ideas?
Thanks.
Andrea.
a-vazquez Fri, 07/14/2006 - 06:20
  • Silver, 250 points or more
There could be an ip address change which is causing the node verification failed problem
koksm Tue, 07/18/2006 - 22:48
Did you configure both ACS servers with their own addresses as agents in RSA?
