configuring a PSTN with CCME
Jul 10th, 2006
  • Green, 3000 points or more
I have a 3825 router and i want to run CCME on this. ALso i would like to terminate a PSTN line which is coming from PBX for outgoing calls.
Can anyone tell me prerequisites required and the configurations needed on my router .
Thanks in Advance
Narayan
gogasca Mon, 07/10/2006 - 11:51
Fe de etarras
It will depend on the connection to the PSTN.
Will it be a T1/E1 PRI,CAS, FXOs other?
Let us know so we can send you a proper config.
royalblues Mon, 07/10/2006 - 19:47
Hi Gonzalo,
It would be an E1.
Narayan
