Warning message
difference between Tunnel and vpn
Jul 10th, 2006
Hi all
I am confused about tunnel and vpn.
I want only up tunnel interface up between two interface but no vpn.
again another siter tunnel with VPN .
my question if i create tunnel interface then i must need configure VPN ????..
pls anyone clear to me ..
Biplob
attrgautam Mon, 07/10/2006 - 23:43
  • Silver, 250 points or more
Very general question. A tunnel will classify itself as a low end vpn but if vpn is ipsec for you, then you dont need an ipsec session for running gre tunnels but your data will not be encrypted
Wilson Samuel Fri, 07/14/2006 - 05:56
  • Gold, 750 points or more
  • Community Spotlight Award,
    Mobile User, July 2015
No, you needn't have a VPN created for a Tunnel interface.
Infact when you have a tunnel with encryption and authentication its called VPN.
I hope that solves the concern.
Wilson Samuel
iqbalkhan Sat, 07/15/2006 - 22:56
HI
Sorry again.My question was VPN and Tunnel.
I configure VPN between two site.
again requirement tunnel create between two site.
so I create VPN then Tunnel interface
[GRE Tunneling].
BUT MY QUESTION WAS, I WANT CREATE JUST ONLY TUNNELING INTERFACE FOR TWO SITE ROUTING -DATA PROCESSING. NO IP SEC. THAT MEANS TUNNELING WITHOUT VPN.
I think you all r understand me about my confution.
