Managment IP for firewall
Aksher
If you are talking about accessing PDM (PIX Device Manger for management) via VPN from a remote site then yes this can be accomplished.
If want to run the PDM from your internal LAN, then again this can also be accomplished.
If you want to connect to the PIX via SSH then this also can be accomplished.
But NO you can not setup loopback addresses on the PIX.
So, which of the above method are you asking for?
Jay
