isdn interfaces
Jul 11th, 2006
on my router, if I am only dialling one destination, do I just set the connection on my bri interface, whereas if i am dialling 2 destinations I would need to use dialler interfaces, is this correct ?
thanks
Overall Rating: 3 (1 ratings)
jstoecker Tue, 07/11/2006 - 14:48
  • Silver, 250 points or more
Carl,
Let me point you in the right direction:
http://www.cisco.com/en/US/products/hw/routers/ps221/products_installation_guide_chapter09186a008007e2e5.html#wp1021741
I think the correct terms are "legacy DDR", which associates a single destination with the interface, and "DDR dialer profiles", which lets you dial different places depending on the network you're trying to reach.
John
ariela Tue, 07/11/2006 - 14:56
in my opinion, dialer interface (and dialer pool, of course) is more desirable, for scalability.
Andrea
