Warning message
desai.jaideep Wed, 07/12/2006 - 03:33
  • Gold, 750 points or more
Hi Carl
Didn't the link I gave to you helped?
JD
gwhuang5398 Wed, 07/12/2006 - 06:23
Here is what you can configure on each router. One would be the mirror of the other.
Assuming using Loopback0 of each router as the IPSec tunnel peering point. Let's make up 2 loopbacks: 1.1.1.1 and 2.2.2.2 for Router 1 and 2.
On Router 1:
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key xxxxxxxxxx address 2.2.2.2
crypto ipsec transform-set MY-IPSEC esp-3des esp-sha-hmac
crypto map remote 5 ipsec-isakmp
set peer 2.2.2.2
set transform-set MY-IPSEC
match address MY-NETWORKS
ip access-list extended MY-NETWORKS
permit ip xxxx xxxx xxxx xxxx
Make sure the two routers knows each other's loopback. This will get the tunnel set up from the host network of router 1 to the host network of router 2.
Reverse source and destination on Router 2.
carl_townshend Wed, 07/12/2006 - 07:56
how would i make sure they know about each others loopback ? would I have to put a static route on each pointing to the serials ?
dhillyard Wed, 07/12/2006 - 10:44
If you're dependent on the single serial link between the two routers, there is no need to tunnel to a loopback. Just use the serial interface.
Also, newer ios code allows you to apply the ipsec right on the tunnel interface. It's really slick. Set up the global crypto ipsec profile, then just apply the following command to your tunnel interface:
tunnel protection ipsec profile PROFILE_NAME
gwhuang5398 Thu, 07/13/2006 - 09:13
The easier way is just to use the serial interface addresses instead of the loopbacks. The two serial interfaces know each other as connected.
Let me know how that works out for you.
Gary
royalblues Thu, 07/13/2006 - 20:32
  • Green, 3000 points or more
Can we have IPSEC configured without using the AIM encryption Module ?
to my knowledge i dont think it is supported on the 1700s
regards
Narayan
carl_townshend Fri, 07/14/2006 - 02:07
how would we reach these loopbacks, would we need to point the loopback address to the serial on the other end ?
royalblues Fri, 07/14/2006 - 02:16
It has to be advertised in your routing protocol if u are using any or use static routes
