AAA Configuration
Answered Question
Jul 12th, 2006
Hi There,
I configured AAA on my switch as follows:
aaa new-model
aaa authentication login default group tacacs+ local
After enabling the above commands I got AAA to work on both Telnet and console access without applying:
line console 0
login authentication default
line vty 0 4
My question is why was the AAA authentication activated on the console 0 and vty 0 4 lines without applying the AAA config on them? And since this has happened how can enable AAA only for telnet access and not for console or vice versa?
Haitham
Correct Answer by tdrais about 11 years 1 month ago
That is what the "default" is for. Just don't use the default and make up another one. That one will only apply to the interfaces you activate it on.
Mnay people use the name CONSOLE for the console but it is just string of letters there is nothing special about it.
Overall Rating: 5 (2 ratings)
Correct Answer
tdrais Wed, 07/12/2006 - 05:55
  • Blue, 1500 points or more
