Warning message
hemendoz Wed, 07/12/2006 - 17:09
  • Cisco Employee,
Hello Paul,
I have worked with clients who have AS400 traffic that passes through a ASA VPN tunnel. The only issue we had is that sometimes connections could go idle for long periods of time, and if the ASA connection timeout is set too low, this traffic would not pass after the idle time-out period. We'd have to physically reset the AS400 interfaces for traffic to flow again. You can set infinite idle time-out periods based on specific hosts now on 7.x (Modular Policy) vs. configuring a global value.
Here is a link that details this
PIX/ASA 7.x: Set a Connection Timeout Based on an Access-List Configuration Example
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a0080624e19.shtml
Any specific traffic you are concerned about?
Hope this helps! If so, please rate.
paulnigel Wed, 07/12/2006 - 19:43
Hi hemendoz,
Appreciate much for your help.
correct me if i am wrong, when my AS400 communicate with Rumba(emulation software), they use Telnet, 1789 and ack traffic is like using tcp high ports, 8192.
does it mean that i have to set ACL for infinite idle time-out for all the ports that the clients used? or do you have a better solution?
Thanks and Best wishes,
Paul
