CME 3.3, CUE 2.2.2, IOS 12.4.2T4
Answered Question
Jul 13th, 2006
  • Purple, 4500 points or more
Have a CME integrated with CUE (versions indicated above). MWI numbers have been defined in the CME box as follows
ephone-dn 3
number 8000
mwi on
ephone-dn 4
number 8001
mwi off
When I run CUE initialization wizard, it doesnt pull the MWI numbers (it says no MWI numbers are defined).
I have tried resetting the CUE/CME configs to defaults and re-initialize with no luck.
If I go to Control panel in CUE and click Synchronize, it says that the MWI are not defined in CME.
I manually tried to key in the MWI numbers via CUE CLI and still no luck.
ccn application ciscomwiapplication
description "ciscomwiapplication"
enabled
maxsessions 6
script "setmwi.aef"
parameter "strMWI_OFF_DN" "8001"
parameter "strMWI_ON_DN" "8000"
parameter "CallControlGroupID" "0"
end application
Correct Answer by Jed Renton about 11 years 1 month ago
Do your MWI numbers match your dialling plan eg
8001....
with 4 wildcard characters for 4 digit dialling
Overall Rating: 5 (1 ratings)
Correct Answer
Jed Renton Thu, 07/13/2006 - 16:36
8001....
thisisshanky Thu, 07/13/2006 - 16:46
Duh..
thats exactly what i was missing. Thanks man..
Cant believe i missed that..
Sankar.
